It is currently Thu Aug 21, 2025 5:39 pm
 Post subject: Cutting a Sound Port
PostPosted: Fri Jul 12, 2013 10:58 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Just wondering if anyone cuts their sound port before bending the side. I actually use my scroll saw to do a lot of my fine cutting, and was thinking that it might be easier to cut out a sound port with my scroll saw before I bend the sides assuming I can get the port oriented correctly. Thanks.
 Post subject: Re: Cutting a Sound Port
PostPosted: Fri Jul 12, 2013 11:24 am
Bend first
PostPosted: Fri Jul 12, 2013 1:34 pm
Like Steve said, bend first. Otherwise it's difficult to get a smooth bend.
PostPosted: Fri Jul 12, 2013 1:39 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
What Steve said, because:
If you cut the hole first, that section of the side will bend more easily so you're likely to get a kink at the center of the hole. Of course, now that you're aware of that potential problem, you can take measures to avoid it, such as using a good backing strip when you bend near the port.
PostPosted: Fri Jul 12, 2013 1:53 pm
Remember also that you are better to laminate a Side Port area to strengthen it anyway
PostPosted: Fri Jul 12, 2013 6:23 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Clearly the consensus is to bend and then cut. I will reinforce the area. Thanks guys!
Users browsing this forum: Chris Ensor, TripodBob and 17 guests
